So a while back I got the CPU fan error on boot. The fan inbetween the 2 towers on my dark rock 3 is broken. And I'm too lazy to remove my GPU to take it away. (No real reason to replace atm since it's winter here temps never go above 65, even with 1 fan)
So I thought just disconnecting the fan would get rid of the CPU fan error... Nope. It still shows the CPU fan error, while the broken one is disconnected and the other one is plugged in to the CPU fan header.
Help?
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/482341-cpu-fan-error-bug/
Chances are the fan is running slower than the bios' 'minimum' speed. You should have an option in your bios to set the lowest 'normal' speed for the fan to about 200 or 300 rpm. This fixed it  for me on my Noctua NH-D15 in the past.
https://linustechtips.com/topic/482341-cpu-fan-error-bug/#findComment-6470835
Ah sweet, thanks
https://linustechtips.com/topic/482341-cpu-fan-error-bug/#findComment-6470842
