Fan header extremely hard to remove
Don't know why, but it's impossible to remove a fan header I'm simply trying to unplug to test some things. Pulling straight and out is not working for some reason, and I really don't want to uninstall my gpu or psu to get it out. http://puu.sh/leQkq/1a140b70b2.jpg
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/481648-fan-header-extremely-hard-to-remove/
Get some pliers and try pull it out slowly. Make sure the system is off so you dont short circuit anything.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
The one at the bottom?
..are you serious about not being able to pull it out? Did you super glue it or something?
You don't need to be a jackass. No, I didn't glue it, and no, it doesn't come out.
You know what I just noticed? The plastic housing moves, but not the wires.
The tab on the housing is stuck. Try bending the tab out a bit.
