I was screwing around with shadow play uploading, the quality was actually ok even on min settings but shadowplay has some issues IE needing to be full screen and I couldnt get KSP or ...something else to stream so im looking at OBS but Im wondering what settingfs to use I have about 0.85 mbps in upload speed, I was intending to use the Nvidia NVENC encoder since I imagine thats what shadowplay uses but other then that I dunno what to use for any of this stuff.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/481235-obs-settings-for-low-upload-speed/
Streaming with slow internet is not an option, unless you want the stream to look real shit Sorry
as ive said ive already done it via shadow play and it was acceptable.
System Specs
I have basically the same upload and tried to stream multiple times and it didn't work ...
Thankfully , i'm upgrading to 500/200 tuesday
System Specs
