Working out UPS req's?
Solved by W-L,
Ah right, so I was roughly correct with what I was assuming. Not sure what he has off the top of my head for the full build, but using mine as an example ( http://uk.pcpartpicker.com/user/Mattch23/saved/dzGwrH )
Would I be correct in saying that if my max load is 598w then aprox 22 for 1 screen at least a 620W (minimum) PSU would be sufficient?
Ok so if the system draws about an absolute max of 600W and with added monitors, peripherals and networking an extra 50 watts or so, something like a ~700W UPS unit should be more than sufficient.
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BR1200GI&total_watts=200
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BX1400UI&total_watts=200
