Uhh, what?
Have you pressed something on the keyboard? Moved the mouse?
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
This might sound silly but, is your monitor turned on ?
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
Uhh, what?
A little more of an explanation might help people help you ;)
alroght so I turned on my tv it's hooked up to my mother board via hdmi all the lights indicating something wrong are off. Now I'm just waiting for something to come onto the screen, or in other words for it to send something to the tv to display. But it hasn't happened yet. My question is do I need to wait for something to send to the TV or do I need to start by putting the motherboard driver installation disk in the optical drive?
-snip-
What is the TV's "input source" ?
I am who I am.
If you have a dedicated GPU(Nvidia/AMD card), you need to plug the HDMI cable to it, not the motherboard's.
Make sure the input of the TV is correctly set to HDMI (and if it has multiple HDMI sources, make sure to select the right one)
If you still don't see anything, when you power the machine, does it make any beeping sound? It should, normally, make a single "beep" on startup.
Is the screen black the whole time, or does it display the bios/POST information on boot and then blackscreen where windows should've loaded?
Please explain better.
i do have a dedicated gpu and the hdmi cable wasn't going in so I didn't do much more trying on that, I'll try again. And no it's not making a beeping noise. I didn't hook up anything to make sound so that might be why unless the motherboard has something on it.
im not seeing anything on the screen right now and my system is running and it's working fine. How long do I have to wait for it to show something on my screen? Or does it even do that? I haven't installed the drivers or anything yet
If it's not showing up on your screen, it probably isn't working fine lol.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
Are you putting it in the display port port?
Can you send a picture of what you're trying to do?
Well keep trying... Because unless you remove that GPU, it ain't gonna work with the Onboard. You NEED to plug the cable in the graphic card itself.
thanks for the help I figured it out a while ago. I just need to plug it into the gpu
How do I mark this as solved?
there should be an option to Mark as Solved on someone's post, near the Quote/like/report on the right side.
LMFAO i had so much fun reading this. Thank you for this entertaining post. I almost thought it was fake.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
I'm still not convinced it's real.
