Which LAN cable?
Go to solution Solved by SPAS-ID,
CAT6
Hello Folks!
I'm not vergy good with the whole Networking stuff, so I'm asking you folks.
So at the moment I'm using a CAT 5E cable and for some reason it doesn't give me the full upload speed I'm supposed to get.
My living room computer that uses a different cable has the full 900M/bits, but my main computer only gets 10M/bits.
Now I'm looking into getting a new cable since the one I have is pretty old anyways.
Now my question is, what ype of cable should I get since there are so many different ones?
CAT 5? CAT 6? Cat 6A? I'm confused with that.
Thanks!
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/480179-which-lan-cable/
Simple answer, thank you!
just incase this is a sarcastic, My Internet speed went up if i change to CAT6, i thought it just a coincidence i tried it again and its the answer
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/480179-which-lan-cable/#findComment-6441734
Nah it's not meant sarcastically, but thank you.
https://linustechtips.com/topic/480179-which-lan-cable/#findComment-6441747
your getting nearly a gigabit?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/480179-which-lan-cable/#findComment-6441823
Well, I /should/ be getting it, but I don't and the moment.
damn in our area its amazing to get 40 Mbits
}else{
https://linustechtips.com/topic/480179-which-lan-cable/#findComment-6443166
