So the title says it all really, If You were to make an OTT PC Is there a way you could water cool SSDs with a block or something that is purchasable on the web?
More of just a question
Depends which ones.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434111
EK has a waterblock for Intel's pci-e SSD, but I don't know about any others.
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434115
Like 2.5 inch SSD?
I don't believe those exist nor would they be necessary for SATA III SSD' s.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434124
Like 2.5 inch SSD?
don't/can't generate enough heat to ever make it worthwhile If you really must you could probably slap a RAM block on it, but it shouldn't make a difference.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434130
Depends which ones.
I think you can watercool the pcie ssd's but that cost's shitloads.
I thought you might be able to get pcie ssd water blocks because they chuck out quite a lot of heat
But wasnt sure
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434133
Like 2.5 inch SSD?
use a thermal pad like the ones used in gpu vram coolers and stick it to a universal waterblock. Not the cpu ones, but the general use "box" kind
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434134
This.
Except water cooling storage is pointless as all fuck.
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434141
Like 2.5 inch SSD?
Yes i did this to mine. I just stuck a custom water block I had made ( very small) and it somehow worked and looked pretty awesome :D.. TBH you can probably get any standard water block assuming it would fit.  Storage doesn't need water cooling by any means..  but for looks :)
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434184
It's not needed.  My case has no fans except the one in the PSU and the SSDs (4 of them) all sit fine with 0 air flow.  The WD Caviar Black also works fine with no air flow.
If you were ambitious enough, you could use some thermal tape and stick a couple SSDs to this: http://www.lytrondirect.com/store/cold-plates/?F_ValueIds=70
I use those to watercool my backplates on my X's.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/479666-water-cooling-ssds/#findComment-6434970
