I currently have a 49u rackmount. It has 4 140mm fans at the top but besides that there is no airflow ( as far as i know)
Any suggestions? How are the machines getting enough air for intake?
I left the back door off.. The two side panels are on and the front door is closed.
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/479664-rackmount-cooling/
Well, considering most rack mounts are in data centres with their massive air conditioning, you're really out of luck unless you have a way to pump air in and out of that room.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/479664-rackmount-cooling/#findComment-6434157
the " room" is plenty cool.. Its inside the rack thats the problem
https://linustechtips.com/topic/479664-rackmount-cooling/#findComment-6434165
Take off the side panels and have a circulating fan push the air around.
https://linustechtips.com/topic/479664-rackmount-cooling/#findComment-6434183
