Question on setting up fan.
I have question on Fan. I have a ITX motherboard with one SYS_FAN and CPU_FAN on it. I've connected the stock CPU cooler to CPU_fan and a front fan to SYS_FAN. I have a rear fan which I used a molex connector to get it working.
I was planning to install a top fan for my casing but I can't find any slot to put in. Do i need something extra to get it working?
Also, in the future, I was planning to upgrade to a Fan Controller with total of 4 Fan. What do I need?
Lastly, I notice I have one extra cable on my fan which i did not use and it still works and my led still light up. (LED -/+ wire stated) for Bitfenix Spectre Pro
Casing: Bitfenix Prodigy
Motherboard: Gigabyte H87n-wifi
Chassis: Corsair 540 AIR | CPU: i5 4670k @ 4.5Ghz | Motherboard: Z87 Sabertooth | GPU: Asus GTX 780 Direct CU IIRAM: 16GB Avexir Core Series 1866mhz Blue LED | SSD: Samsung EVO 250GB HDD: Western Digital 1TB Blue | Coolers: Corsair H100i
Build Log: Project Sapphire
https://linustechtips.com/topic/47920-question-on-setting-up-fan/
I think you'll love this.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/47920-question-on-setting-up-fan/#findComment-636257
