99% Memory usage / memory leak! Help!
So my memory usage is between 95-99% currently , i have no idea how, control panel doesnt show any program using so much
im getting some weird freezer right now ,
my memory is Corsair Vengeance Pro 2133mhz, at my custom timings 9-11-10-30
im gonna try increase the timing tommorow and see if its fine!
other thread related to this issue
http://linustechtips.com/main/topic/476954-high-memory-usage/#entry6391448
windows 8.1 pro***
- also** my OS drive only has 4.5GB of free space,maybe this is related!?
- i ran malwarebytes yesterday and it didnt find anything!
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/479129-99-memory-usage-memory-leak-help/
Reboot? Also, your specs would help us out. What programs are running anything like Chrome or known to leak memory. I believe there is a memory leak issue in Windows 10, but not completely sure. We need more info.
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
specs on my profile
does noone check profiles for specs on this forum :D
yes reboot fixes it ,but whats the cause!? this started happening recently
and i use firefox, and steam is open all the time
closed these programs and some nvidia processes, still now its 98%
Post a Screen shot of your task manager processes, that will probably clear some stuff up!
Edit: just skimmed through your other topic, post resource monitor of RAM as well.
My Rig:
Model: P650RG | Brand: Clevo | CPU: 6700HQ | GPU: 980M | RAM: 16GB KINGSTON HYPER-X DDR4 | SSD: 2x 480GB Kingston KC300 | Screen: 3K Panasonic IPS LED
@wardude1
also my OS drive has only 4.5GB of free space left
It is RAM in use, or RAM caching stuff? Like this:
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
-snip-
Post your resource monitor as well, that might have some more answers! Task manager>performance>resource monitor>memory
My Rig:
just look in the task manager
oh yeah i now see, how didnt i notice this!?
how do i fix it? i know a restart helps but after a while it happns again
also note that i only have 4.5GB of free space on my OS drive, if its related to this?
check my previous post also
small tip: alt+ctrl+prtnscr will take a picture of only the open window
A 120GB SSD fills up quite quickly  ;) but maybe ccleaner can fix some space up for you
EDIT: Im still curious about the resource monitor as well, because I didnt spot 8 GB being used anywhere.
My Rig:
yes, it doesnt show up, i checked its the same as the control panel but more detailed
check my post above ^^^^^^^^
Your disk1 is running at such a high load because it is swapping like crazy. Do you have any programs open that could be using 2-3GB of RAM on their own? Firefox or Chrome with a couple of dozen tabs, a game, anything really.
What happens if you restart the computer? How quickly does the RAM fill up again? Does this happen if the computer is idling?
nope, hmm its at about 5% now, it was at 80% when i open stuff,usually just a high spike, than goes to normal,just ignore the disk is normal
how can i fix the ram usage!?
if you didnt notice my cached memory is only 70 MB, and non paged at 7.2GB ,look at the picture above^^
how can i fix it, if you didnt notice my cached memory is only 70 MB, ând non paged at 7.2GB ,look at the picture above^^
That means you have 7.2GB of "user stuff" (i.e. not hardware reserved) in RAM and 70MB of "spare" RAM for caching stuff for later. So you basically have 8GB of RAM, 8GB of page file (of which about 1.7GB is in use for a total of 9.7GB).
but im not using anything, the most currently using is firefox, and its using 150MB
My Rig:
As I just skim read this, I believe it's not been mentioned...
What OS are you running?
The issue might be that you've not got a Paging file.
Presuming you haven't...
Type in your Start Menu; "Advanced System Settings" and head to the Advanced section. Open the Settings tab in the Performance section under Advanced. Head over to Advanced within this and make sure that the "Adjust for best performance of:" part has "Programs" selected.
Underneath the Virtual Memory section, there should be a number measured in MB that tells you the "Total Paging file for all drives". Tell us this number.
Thanks!
I am a Tech Enthusiast; Gamer, Computing student; Small YouTuber and a keyboard warrior :^)
System Specs:
CPU: AMD FX-9590 8Cores@4.7GHz (5GHzBoost) | RAM: 16GB (Mixed Kingston&Corsair) | GPU: ZOTAC GTX 960 4GB | Case: Bitfenix Merx Alpha | Storage: Samsung 850 EVO 120GB [BOOT]; 240GB OCZ SSD [Games] ;1TB SSHD | PSU: 800W something | Displays: AOC 24" 1080p 16:9; Yuraku 19" monitor | Cooling: Noctua NH-D15 | Keyboard: Razer Blackwidow 2014 Tournament Edition [Green Switches] | Mouse: Razer Deathadder 2013 | Mouse Pad: Razer Vespula | Audio: Razer Tiamat 2.2+ Razer Hammerheads Pro | Operating System: Windows 10 Home
Thanks!
yes and yes
minimum 16MB
recommended 4561
currently allocated 8192
now my memory usage is 1.6GB , still high ,no program is using that much!
oh and im on windows 8.1 pro
edit: now its at 99% again -,-
