Monitor for 980ti sli
cruztony
I know with these cards i could be able to run games in 4k at decent fps. But is it worth going to a 4k gaming monitor, considering price and input lag? What monitor would you recommend, doesnt have to be 4k?
I would say a 1440p 144Hz or something similar
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
Any suggestions?
1440p 144hz is a good option. ASUS PG279Q to be exact.
IPS
144hz (165hz OCed)
1440p
G-Sync
What more could you want?! So perfect  :wub:
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Any suggestions?
The ASUS PG279Q as the others suggested
PG279Q will be the last monitor you need if you get one that is perfect out of the box. Having said that its worth the gamble. The way I see it 4k is nice and all but the performance hit is way to much to justify.  Sure you will be able to run anything now at max settings at 60fps but I would rather have some breathing room for future game releases!
i7 5820k, Asus Deluxe x99 3.1 board, 2 Strix980tis Sli, Intel 480gb SSD, 4T WD Black, Asus PG278Q, Acer xb271hu, UpDesk!
You guys are the best thanks for the advice. Looks like we have aa winner.
Forget 4k. Too much performance loss. Go for IPS 1440p 144hz. Acer xb270hu or Asus pg279q.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Thanks for the advice
