Router Help
Solved by Patrick3D,
Check with the University IT department, or whichever group/company is responsible for the network connection in your room and ask them if you are permitted to connect a router to your Ethernet jack. Some universities restrict Ethernet connections to a single MAC and require a client login to establish connection. If you connect your computer to the Ethernet jack do you have to register or agree to an acceptable use policy before being able to access websites?
If they permit routers you can get a small access point like a TP-Link TL-WR710N that just plugs into a power outlet and has an Ethernet port and built-in router.
