Also, just because I am lazy, look into the youtubechannel JayzTwoCents, he is the community-named Water-Cooling Guru :3
https://www.youtube.com/user/Jayztwocents
yup that
Yes I'm buying from eBay but the components are not used. I would like to know what I need to build a custom watercooling for a cpu please (like tubs etc)
You need tubs, waterblocks, radiators, fans, pump, reservoir etc..
Google won't bite you ;) Or check JayzTwoCents' channel for more.
Give me a boost.
And fittings, you need fittings too. 2 per component each so you will need at least 6 if the pump and reservoir are a combo. Most components and fittings have a G1/4 screw thread so you can't go wrong easily on that. However, there are a lot of different tubing sizes you can use. You need to pick one that fits on your fittings. The inner diameter (ID) is important here and when you use compression fittings the outer diameter (OD) becomes important too.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
Alright guys thank you :)
No problem. :)
Don't buy no name stuff from eBay.
Buy trusted brand.
