if you get an even slightly decent case the fans that come with it will do fine.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/478022-fans/#findComment-6404592
Good, dedicated, quality, and friendly fans.  Not to mention quiet.
ambiguous
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/478022-fans/#findComment-6404608
personally i would get S340 and move the fan 1 on the Top and 1 on the Rear
LTT fans  B)
its so expensive (assuming he only had 900$)
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/478022-fans/#findComment-6404666
I have heard good reviews about those fans, they are PWM too. I think they come with a PWM splitter so you can run more off of one port. Good for the price.
https://linustechtips.com/topic/478022-fans/#findComment-6404875
from a raw quantity to price ratio. yes.
but I still wouldn't buy them. there should be a LTT video going up today that analyses how the number of case fans effect temperatures. which basically showed that the difference between 2 fans and 5 fans was only about 4 degrees. and most cases come with 2 fans that will be just fine.
Edit: this is what i'd do for a $900 build (with no extra fans, there are 2 good fans that come with the case, just leave 1 in the back and put one in the front):
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($186.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI H170A PC Mate ATX LGA1151 Motherboard  ($88.20 @ SuperBiiz)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($198.98 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($60.98 @ Newegg)
Total: $844.13
Generated by PCPartPicker 2015-11-02 22:41 EST-0500
https://linustechtips.com/topic/478022-fans/#findComment-6404881
