Random restarts and freezing
Solved by CyberHippie,
I had a similar issue a while back...
When I did my new build, I installed 4 sticks of ram (32gig) 2 pairs....
It started to do exactly as you said so I started troubleshooting and went straight to the ram
I noticed removing some sticks fixed the problem while others caused the problem, so I fiddled about till I found the bad stick and removed it, along with its matching pair, so I now run 16gig
Sometimes its easier to diagnose the problem physically, rather than using software testing ![]()
