If it goes away after a few seconds it should be fine.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/477605-red-light-on-mobo/#findComment-6398975
Hey I recently just built a new pc but when i turn it on there is a red light by the usb 3 slot. What does it mean and will it affect anything?
Please read the instructions you got with your motherboard, they will explain all this there.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/477605-red-light-on-mobo/#findComment-6398976
is there something written next to it? my red led next to my usb 3.0 header is for ram issue, what is your mobo?
https://linustechtips.com/topic/477605-red-light-on-mobo/#findComment-6398977
