Today I built myself my first gaming rig.
Specs: https://azerty.nl/winkelmandje/winkelmandje/?legen=1&product%5B528532%5D=1&product%5B683472%5D=1&product%5B688141%5D=1&product%5B635920%5D=1&product%5B834177%5D=1&product%5B692496%5D=1&product%5B635005%5D=1&product%5B739755%5D=1&product%5B827192%5D=1
When I finally finished building I noticed problems. The system would power on, and I could connect to the BIOS and the system would shut off after a few seconds.
Then I changed the 2x4pin CPU power connectors to 1x8pin and it started working.
Then I carried my rig upstairs to install windows.
Now when I turn the system on nothing happens. No fans spin, not even the case fans which are not connected in any way to the motherboard (molex cable).
Now I'm desperate. I think I have a faulty power supply because the case fans do not spin, or maybe I connected the power switch headers the wrong way?
Help?
Chavelo
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/476419-urgent-help/
unplug your psu and take it to a store
Specs: i7-4790k with Thermaltake Water 3.0, EVGA GTX 970, MSI Z97 Gaming 3, Kingston HyperX 2x8 DDR3 1600Mhz, SSD Boot Drive/1TB HD, CM Storm Stryker, EVGA Supernova G2 750W
Peripherals: SS Rival, HyperX Cloud, G710+
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384611
Did any cables get unplugged when you carried it upstairs?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384613
Help?
Chavelo
what 8-pin did you plug into the CPU power , you may have plugged in a GPU cable
My Pc Specs
CPU : AMD FX-8350 @stock w/Noctua NH D-14   Mobo: Asus M5A99FX    Ram : 16gb Corsair XMS3 @1600mhz    GPU : Gigabyte GTX970 Windforce OC 4GB @1429mhz   SSD: Sandisk X110 256gb    Case: Be Quiet Silent Base 800 Windowed  PSU: EVGA 850w g2  Peripherals : Corsair K70 w/Red Switches , Logitech G502 , Samsung SyncMaster S22B300 (1920x1080) , Ttesports Shock one headset , Phone : HTC one A9
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384614
Nope
Only HDMI and power cable to PSU
Not labelled. But AFAIK the PSU only has 2x6+pin for GPU
Project Pluto
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384618
Nope
I meant the cables inside the case.  Check there.  Also, is the PSU switch switched to on?
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384639
Nothing unplugged, only side panels. PSU is switched to on. Nothing happens.
Project Pluto
https://linustechtips.com/topic/476419-urgent-help/#findComment-6384693
If that's your suspicion, test the power supply:
Disconnect it from everything in your case.
Then google, "psu test" so that you can learn which pins to short.  When the PSU is plugged into the wall and the power switch is on, when you short those pins, the power supply should turn on and the fan should spin.  If it doesn't, the power supply is dead.
(EVGA includes a plug with new power supplies for this exact purpose.)
https://linustechtips.com/topic/476419-urgent-help/#findComment-6385910
PSU worked
I'm now on my new pc, I installed the front panel headers the wrong way. I'm good now, but thanks!
Project Pluto
https://linustechtips.com/topic/476419-urgent-help/#findComment-6387802
