Hi guys, I was owning a RM 1000 and customize the cable for it, but now I found rm 1000 has some current noise which is a little bit loud, and I bought a HX1000I to replace it. Now can you plz tell me that can I use the customized cable for my new psu? or I need to customize it again?
https://linustechtips.com/topic/476297-cables-problem/
