high idle temps with AIO
Go to solution Solved by Kaitodesu,
How are your temps looking?
yesterday when i noticed it was 88 celcius and after new paste and some cooling down it idles at 60. after shaking the rad and swapping back to the stock cooler , i'm pretty sure the pump is dead so i'll be sending it back to rma
So i haven't been running a overclock on my pentium for a while now and my idle temps are usually 32 degrees with the fan spinning at 600rpm, but this morning all hell broke loose when i hear the fans spooling up and down. upon opening hwmonitor the cpu was 80 degrees out of nowhere.
So far i've replace the old thermal paste to a new one, but idle temps are still 60 degrees with the fans spinning at 2000rpm. any idea what might be causing this?
i7 4770K | GTX 1060 GB
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/
Is your pump running?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/#findComment-6380453
full speed, all the time
if you put your head inside the case, can you hear the pump?
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/#findComment-6380460
the pump on my aio has always been silent so i normaly can't hear noise from it...  however it does have a led on it and it didn't glow when this one time i set the pump speed down, it is glowing now though so i assume it works
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/#findComment-6380463
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/#findComment-6384606
https://linustechtips.com/topic/476116-high-idle-temps-with-aio/#findComment-6387122
