html/css help please :)
Go to solution Solved by Paralectic,
oh, putting 0 padding on h1 aswell as the div got them very close together, thank you, but how would i make them actually touch?
Set a negative margin?
Below in the picture you can see my current web page, i want to make it so the grey bar that has the menu on it is actually touching the page name, so they're connected but i'm having trouble doing so.
Ive tried changing the <h1> tag and even the div the h1 is in padding to 0, so there is no space underneath and that didn't work. i have everything in individual div statements, so the menu is in the container, nav bar and links (3 divs) and the page title is under container and header (2 divs) if that helps. Ive tried padding them to 0 or even auto but to no avail.
if someone could help me here that would be miuch appreciated :) i remember it's not that hard but it's been a while since i did any html so i'm a bit rusty :P
thanks again! :)
post-183800-0-92700600-1446118805_thumb.
https://linustechtips.com/topic/475635-htmlcss-help-please/
Try this:
h1 {    margin:0;    padding:0;}
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373768
do the same for the div of the gray bar ? :)
I am who I am.
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373777
yeah i have, it looks like this now:
#nav
{ background-color: #222; padding: 0; margin: 0;
and there is still a bit of a gap :(
pls
when you do css do it like this :
#nav{     background-color: #222;    padding: 0;    margin: 0;}
makes it a hell of a lot easier to read once you have a lot of it :)
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373860
pls
yeah i did have it like that but since i had so much i found it easier to have it like a new heading every line or 2
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373941
what program do you use ?
if you use bracket you can minimise lines.
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373956
I have a new question, ive just added a search bar, and it's on the left when i want it on the right.. it's in a div called "searchbar" and also in the nav div, so i went:
#nav .searchbar
padding: 50px;
margin: 50px;
float: right;
ive also tried padding/margin left but i can't get it to move at all, anyone know why that is? :)
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6373973
#nav .searchbar
padding: 50px;
margin: 50px;
float: right;
Hmm..
Do you want to do something like this ?
<html>	<body>		<div class="nav" style="width:100%; background:red;">			 			<div class="search" "style="width:10%;background:blue;float:right"> 				 			</div>		</div>	</body></html>
Sorry I can't pinpoint why it doesn't work for you. Try to compare this to your work then see what needs to be changed. :D
I am who I am.
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6374165
Hmm..
not sure what happened but i opened it up again today and the search bar worked, it was like it didn't want to use the css last night, but would today? :P .. but now my footer is doing the same thing.. i declared the footer:
HTML:
<div id = "Footer">
<p> random text  </p>
</div>
then in the CSS i put:
#footer
margin: 0px;
width: 100%
color: blue;
background-color: #666;
height: 75px;
.. it's weird sometiems stuff doesn't work and i have no idea why since it all looks right.. i've opened and clsoed the div, ive used the correct caling "#" for ID "." for class... but the css just doesn't seem to apply, even tho 90% of the other things work fine from the same css file.. :(
edit: that moment you realise css is caps sensitive... *face palm* haha
thanks for all the help guys :)
https://linustechtips.com/topic/475635-htmlcss-help-please/#findComment-6379217
