MYSQL Query Help
Go to solution Solved by Brenz,
You need foreign keys for this.
So I assume you have a user table like:
id | name          | email
1  | John Smith | blah@gmail.com
2  | Jane Doe    | hi@Test.com
So then you would have a ships table:
id | Name     | Description
1 | Ship 1     | Awesome ship
2 | Ship 2     | Its massive
3 | Ship 3     | Kinda rubbish
Now finally you need a table to link a user to a ship. This allows you to create a 1 to many many to many relationship between users and ships:
id | fk_user_id | fk_ship_id
1  | 1               | 2
2  | 2               | 3
3  | 2               | 1
4  | 1               | 3
Now from these 3 tables you can see John owns ships 2 and 3 and Jane has ships 3 and 1. Whenever a person says they own a new ship an entry will be added to the last table
id | value1 | value2| value3
0  | 1         |  2        |3
Can't you make your table like this ?
I'm not sure I get your problem correctly.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372651
You really shouldn't be storing multiple values in a single column. You should create a whole new table to store these values.
One column to reference which id the value belongs to (a foreign key) and the other to hold the value.
Then you could:
SELECT * FROM valuesTable WHERE id = 0 LIMIT 2;SELECT * FROM valuesTable WHERE id = 0 ORDER BY id LIMIT 1
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372730
0  | 1         |  2        |3
No, because the next row might have 1,2,3,4,5,6.
The number of items is unknown.
Then you could:
Because I dont know how many items will be in the list, it would be difficult to put each piece of data into its own cell. Having 200 cells just in case seems a bit unreasonable...
~Judah
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372760
Are you using MySQL only ? Any front-end language used ?
Example: PHP has an explode() function that can separate string values using a delimiter, in this case the ",".
I am who I am.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372784
No, MySQL only.
This is for a friend who is using a different system (Adobe cold fusion I think) which does not like data stored like this. Using the PHP explode function would be nice, but that is not an option here.
We might just have to get a little more creative in how we store the data
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372859
No, MySQL only.
Can you create another table ?
There's an idea floating in my head, I'll just write that down then share it here. :)
I am who I am.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372865
I just realized that my idea is similar to this. I'll try to think of another solution (no promises ! :) ).
Then you could:
I am who I am.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372869
No, MySQL only.
Can you share the process/ workflow you're trying to do ? From the input to the storage and output. Maybe we can get some ideas from there.
I am who I am.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6372876
What is the data? Why do you have a variable number of values for each id? Is there a maximum number of values an ID could have?
It is variable because it is user-inputted data. In this specific form, the user is storing the different ships they own in Star Citizen.
There is no maximum, because the final number of ships that will ever exist is still unknown.
The user inputs the ship they own into an auto-completing text input. If they own more than one, there is a button to add more text inputs. There is no limit to the number of ships they can own.
When the user saves the data, each ship must be saved in a different cell because Adobe Coldfusion does not like reading fields with JSON or CSV data in them.
I also cannot add multiple references to another table in the cell. So I thought that maybe if there was a SQL command to break it up life could get easier
~Judah
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6376636
id | name          | email
1  | 1               | 2
2  | 2               | 3
3  | 2               | 1
4  | 1               | 3
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6376844
id | name          | email
Now finally you need a table to link a user to a ship. This allows you to create a 1 to many relationship between users and ships:
1  | 1               | 2
2  | 2               | 3
3  | 2               | 1
4  | 1               | 3
Actually this is a many to many relationship. A one to many would be to just add a user_id column to the ships table.
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6377217
id | name          | email
1  | 1               | 2
2  | 2               | 3
3  | 2               | 1
4  | 1               | 3
This looks like it will work.
Ill play with it, shouldn't be too bad
~Judah
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6377523
It's pretty simple, you just need to use joins. Using the structure Brenz suggested:
SELECT users.name, ships.name, ships.desc     FROM data    INNER JOIN users ON data.user_id=users.id    INNER JOIN ships ON data.ship_id=ships.id       WHERE users.id=1;
returns
name, name, desc
John Smith, Ship 2, Its massive
John Smith, Ship 3, Kinda rubbish
https://linustechtips.com/topic/475558-mysql-query-help/#findComment-6382203
