Posted October 28, 2015 Yes i know minecraft... the issue i am having is the fact that when i am playing a modded minecraft server it lags for everyone. Such as block lag when you hit a block it takes a second for it to go away. And then when im not there its 100 fine. no lag for anyone. but then when i joined it lags. im running a modde version of minecraft called CrundeeCraft. i did not add any other mods to my game. if you have any questions that would be great. Thanks for the help Link to comment https://linustechtips.com/topic/474886-minecraft-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Turn your view distance down probably, I think if you can't see the chunks the server doesn't have to load them Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363329 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Hmm. The way MC Servers work is they always have to run at the same speed for everyone, which means the delay has to be the same for every one. (You probably have a really high ping) Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363334 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author Turn your view distance down probably, I think if you can't see the chunks the server doesn't have to load them thats not the issue. i tried that but thanks. Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363335 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author Hmm. The way MC Servers work is they always have to run at the same speed for everyone, which means the delay has to be the same for every one. (You probably have a really high ping) oh yah i dont have high ping.... unfortunelty this is going to be a hard one to solve Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363339 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Could use Opis to find out what's causing the issue, and just remove it from the modpack. 3700x, Asus B450i, 16GB Corsair Vengeance RGB, Gigabyte GTX 970 ITX, Dan A4-SFX, SX600-G, 120mm AIO. Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363341 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 oh yah i dont have high ping.... unfortunelty this is going to be a hard one to solve Hmm what is the chunk load distance of the server. EDIT: How much RAM does the server have dedicated to it + how many people at a time? Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363353 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Author Hmm what is the chunk load distance of the server. no idea Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363354 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 You literally said there's a delay when breaking blocks. That's the server catching up with client information. It's either a shitty server or shitty connection. GTX 980 Ti / 5820k / 16 GB DDR4 / 500 GB SSD / ATH-M50X Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363367 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 ^^^^^^^^^^^^^^^^^^^ Comment above me got it right on the money. If it's the server then increase the amount of dedicated RAM. If it's just you lagging then perhaps find a way to increase your internet speed i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363392 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 What are you running the server off of? i7-6700k Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe (Rest of Specs on Profile) Link to comment https://linustechtips.com/topic/474886-minecraft-help/#findComment-6363446 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 28, 2015 Live right next to the servers and you should have no lags. Magical Pineapples
