need help finding an external antenna stand
At least thats what I think its called. Just using this product as an example http://www.newegg.com/Product/Product.aspx?Item=N82E16833166108 where can I get an antenna stand like that or similar to it? Need one for TP-LINK TL-WN881ND http://www.newegg.com/Product/Product.aspx?Item=9SIA24G1722694 need to get the antenna's in a better spot.
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
https://linustechtips.com/topic/474243-need-help-finding-an-external-antenna-stand/
You mean something like this ? Antenna is just a piece of metal. Even if you broke one you can still attach it directly or of course by a replacement
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
