Pc won't post
Go to solution Solved by Tcow,
fixed it, on the PC right now! :)I got a new motherboard and psu and everything went well! thanks for the help
Having a very annoying issue, my cpu fan spins up, my psu fan starts to spin up but then my red cpu error light come on, this is my 2nd mobo, and my 2nd cpu, my parts are
Ram: hyper x fury ddr4
Cpu: i5 6500
Mobo MSI pcmate z170a
PSU corsair cx600m
I will atache a picture of how my lga socket looks because all of the pins look to be bent in the same drection, I am almost positive that I installed my CPU right, lined up the arrors and all? post-270820-0-08767800-1445897192_thumb.
https://linustechtips.com/topic/474175-pc-wont-post/
could be incompatible cpu and you might need to update the bios.
EDIT: try this https://service.msicomputer.com/msi_user/support/techfaqdetail.aspx?formid=3046 (try this with the newest bios on the usb)
EDIT2: if you're trying the method I showed you, please use a graphics card
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6353888
You could try removing all but one stick of ram (the remaining stick of ram should be in the slot closest to the CPU) then turn the PC on.
Also, make sure you have the CPU power correctly plugged in.
Atom14 [Corsair] i5-4690K | Corsair H110i GT | MSI Z97S SLI Krait | 16 GB Team Group DDR3 | Samsung 850 EVO 250GB X2 | EVGA SuperNOVA 850W 80+ Gold | Corsair K95 RGB | Corsair M65 RGB | EVGA ACX 2.0 GTX 980Ti
Corsair KXX RGB Keyboard Cover Mod Make your own using my templates!
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6353902
You've clearly bent 3 pins.
Very very carefully straighten them out using a very small flatheaded screwdriver, if you break one it's a dead board.
Main Rig:-
Server:-
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6353918
Get a motherboard speaker as it will tell you what the problem could be.
I would say remove the ram and try to boot to see if it will give you a new error (the RAM LED should light up) . If it does then that shows the motherboard is at least trying to boot rather than it being bricked.
Put the ram back in, but in slots not used before and try again.
It's not a race to the bottom.
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6354168
The ram is right, I checked the manual, the CPU is plugged in well, but the 24 pin won't click well no matter how much fource I put on it
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6354722
The cpu light is coming on, the ram is fine
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6354726
did you plug in the CPU power? it's the 8 pin near the top of the rear IO, not the 24 pin.
The 24 pin is not the issue here.
Also, the ram could be fine but the BIOS will want to start with only one stick of RAM.
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6355247
Like i said the cpu (8pin) is plugged in fine, i can try with one stick later today but I doubt that it will help
https://linustechtips.com/topic/474175-pc-wont-post/#findComment-6357129
