im planing on building my first gaming desktop. i have previously only used laptops so i am inexpirensed it this particular aria
i curently have a msi ge70 2pe
16g ram
i7-4710HQ CPU @ 2.50GHz, 2501 Mhz, 4cores
gtx 860m 2gb ram
i want to build a gaming pc capable of running curent games like wicher 3 on hig/very high. and still being able to play most new games on high fore the next few yeares
this is my curent plan:
Chassis: Commandar MS-I Snow Edition - http://www.thermaltake.com/products-model.aspx?id=C_00001841
RAM: Crusial DDR3 ballistix sport 2x8gb (1600MHz,1.5v,CL9-9-9-9-24) - http://www.crucial.com/usa/en/bls2k8g3d1609es2lx0#productDetails
MotherBoard: ASUS Z97-P,LGA1150 Socket. - https://www.asus.com/Motherboards/Z97P/
CPU: I5-4690K,LGA1150 Socket. -http://ark.intel.com/products/80811/Intel-Core-i5-4690K-Processor-6M-Cache-up-to-3_90-GHz
Graphics: EVGA GeForce GTX 960 4GB -http://www.evga.com/articles/00914/EVGA-GeForce-GTX-960-4GB/
Powersupply: Corsair VS450 -http://www.corsair.com/en/vs-seriestm-vs450-450-watt-power-supply
SSD: Kingston SSDNov300 - 120gb - http://www.kingston.com/en/ssd/v
HDD: Western didgital 3tb
fans: how many do i nead?
cpu cooler - do i nead one?
1. wil this settup be more powerful than my curent laptop?
2. are all thies parts compatible with eachother?
3. wil i be able to overclock with this settup?
4. are there things that i could save monney on?
5. are there things that  i nead to spend more money on?
6. tips? improvements?
thanks ;)
https://linustechtips.com/topic/473630-planing-first-build-will-this-work/
They're compatible but highly un-optimised- you could a lot better for your money, like this
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ Micro Center)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($22.89 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($115.89 @ OutletPC)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory ($78.89 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive ($149.89 @ OutletPC)
Video Card: MSI Radeon R9 380 4GB Video Card ($224.99 @ Micro Center)
Case: NZXT S340 (Black) ATX Mid Tower Case ($59.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX US)
Total: $1057.41
Generated by PCPartPicker 2015-10-25 20:25 EDT-0400
This will be better. What is your max budget?
What's your budget, and what country?
hard to say since i live in norway so prices are different.
but lets say about 800 dollars
oh and i already have the ssd and hdd, so you can subtract that from the equation
the Commandar MS-I Snow Edition is currently on sale here - any downides to using this one instead? (also i think it looks nicer)
wil i really need 750w?
how about overclocking. im a total newb when it comes to this. is this settup capable of it and to what degree
what about fans - any recomendations, how manny?
again , this is ment fore 1080p on one monitor and 60 fps is plenty
i mentioned above my budget is 800 (not including hdd + ssd). i could probably strech that to about 1000 if i would end upp with something vastly superior
Well, I'd suggest you get a locked i5 if it's signifigantly cheaper, and drop the SSD, and then used the saved money to get your GPU up to a 390, or a 970 if the 970 is much cheaper where you are.
You just need to step your PSU up to a 500W or preferably a bit higher
Ok then. Yeah, cases are personal preference, so if you like it then go for it. As for overclocking, if you don't need the extra performance, then you can save quite a bit of cash by going with an i5-4460 and a h97 motherboard. If you do, then maybe you could buy a more powerful CPU cooler, maybe even a water cooler.
Yeah, you don't need 750W, you could probably get away with 600W.
16g ram
gtx 860m 2gb ram
thanks ;)
I would get one additional 120mm fan for the front.
An after market cpu cooler is required if one wishes to overclock the cpu. It is advisable, but not necessary for gaming systems.
  1. New system will have better gaming performance and faster storage. The cpu will do better with multi-threaded applications and high workloads.
  2. Yes.
  3. Not without an after market cpu cooler. But otherwise, yes.
  4. Don't know. Put it in pcpartpicker.com.
  5. Yes, the psu and ssd.
  6. Better psu. Better ssd, ideally 240GB+. Consider going with Skylake instead of Haswell. Eight GB of memory would be enough. A better gpu.
