Hello,
I am looking for a sub 50€ case with a window.
I have been looking at LC-Power Gaming 975B, does anybody have opinions on this case?
I am open for suggestions.
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
https://linustechtips.com/topic/473385-case-for-build/
Hello,
I am just asking ok, ...
So, you spend extra money to get components that look good through the window yet you ask for a 50€ case, is that corREKT?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/473385-case-for-build/#findComment-6344534
Wont really cost me extra (except for led fans)
https://linustechtips.com/topic/473385-case-for-build/#findComment-6344677
