SO I HAVE 2 LISTS OF BUILDS I PLAN TO START SOON, I AM LIMITED ON CASH AS I AM A STUDENT AND TRY TO WORK AS MUCH AS I CAN TO MAKE THE MONEY I NEED. CURRENTLY, I HAVE AROUND £800 AND STILL SAVING...
ALSO, TRYING TO GET PARTS THAT MATCH UP IS VERY ANNOYING, FOR EXAMPLE MOTHERBOARDS TO CPU's AND RAM.
SO HERE ARE MY 2 BUILDS... CHEAPER FIRST THEN THE MORE EXPENSIVE ONE AFTER...
Intel Core i7-5820K Haswell-E 6-Core
MSI Z97A GAMING 6 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.1
HyperX Fury Red Series 16GB (2 x 8GB) 240-Pin DDR3
GIGABYTE G1 Gaming GeForce GTX 970 GV-N970G1
Intel 730 Series 2.5" 240GB SATA 6Gb/s MLC (SSD)
Western Digital WD Green WD10EARS 1TB 5400 RPM 64MB Cache
ENTHOO LUXE BLACK
I7 6700K 8M Skylake Quad core 4,0 GHz
ASUS ROG MAXIMUS VIII HERO LGA 1151 Intel Z170
HyperX FURY 32GB (4 x 8GB) 288-Pin DDR4
MSI GeForce GTX 980 GTX 980 GAMING 4G
Western Digital RE WD2001FYYG 2TB 7200 RPM 32MB
ENTHOO LUXE BLACK
CURRENTLY, I DO NOT KNOW HOW MUCH POWER I WILL NEED FOR EACH RIG BUT SUGGESTIONS ARE NEEDED!
ALSO, ME THEME IS RED AND BLACK...
CHEERS GUYS!
https://linustechtips.com/topic/473240-help-with-pc-builds/
STOP YELL AT US PLEASE!!
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/473240-help-with-pc-builds/#findComment-6342824
ENTHOO LUXE BLACK
Erm, 5820k is a LGA 2011-3 socket, and the mobo/RAM is LGA 1150 compatible.
For the 5820k you are going to need 2011-3 socket mobo, and DDR4 Ram.
TheRedDragon    |i7-5820k (4.2Ghz) || MSI X99S SLI Plus || Crucial 2x8gb 2133hmz DDR4 || MSI GeForce GTX 980Ti 6Gb || Sandisk 128Gb SSD || Seagate Barracuda 3Tb |EVGA 1000W 80+ Pltnm ||
dossium.net >
Posts that won the internet - Verticle Mice
https://linustechtips.com/topic/473240-help-with-pc-builds/#findComment-6342839
what ram/processor would you suggest? I was going for DDR4 on the skylake chip set because of its higher price so I think im going to need something different with ddr3 for the cheaper build.
https://linustechtips.com/topic/473240-help-with-pc-builds/#findComment-6342877
