One of my fans (dont know which) is making a lot of noise. It vibrates the case and sounds irregular so I was wondering what is the best way to fix the fan? Should I just take all the fans out of the case, inspect them, and then put them back in?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/472844-fan-noise/
Oil it first. Sometimes they vibrate due to a lack of oil. Just jam your fingers in each fan to figure out which fan it is, and then pull the sticker and rubber cap off the back and oil it. @iamdarkyoshi uses engine oil. It works great. He has had sleeve bearing fans last 15 years.
https://linustechtips.com/topic/472844-fan-noise/#findComment-6338270
I don't recommend it, I've lost skin by doing that :D
Other systems I've built:
https://linustechtips.com/topic/472844-fan-noise/#findComment-6338301
