bootmgr issues
Solved by Atmos,
Is it on the same storage drive? If so that sucks balls.
Maybe try to re-install windows on a partition (leave the 80gb used and then re-install on the other part)?
EDIT: Create 50/50 partition split?
Do you have a system restore lying around on external HDDs or USBs?
If it's just the data you need, then you should be able to make a bootable linux usb, and recovery your data from that. Linux supports NTFS
os has killed itself now completely. ive thrown one of my scratch drives in and am using robust copy to move data off in cmd. it will take me probably staying up for the next 8 hours to move everything, but at least this way ill get a fresh instal of w7 lol...
fuck my cities shitty old 50`s power grid.
