check your wifi signal strength
is it the full 5bars?
are you close to the router
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329076
What type of connection are you using? is it 5 Ghz or 2.5 ghz connection. Where is the router located/ how far away from your computer is it. Is it going through many walls? these could all be part of the problem
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329081
2.5GHz and its only started happening since the aus cs go servers were down
Your future is whatever you make it. So make it a good one - Emmett Lathrop "DocBrown
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329092
Try moving channels... 11 is the default and most congested channel...
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329100
How would i do that
You need to go to your routers' settings page usually 192.168.1.1 or 0.1 username is usually username and password is usually password if you've never been into it before
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329131
IITs on channel 6
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329138
set it to auto or select a different channel
it under the router settings
on your web browser type 192.168.1.1
login ID admin/administrator
password: admin/administrator
https://linustechtips.com/topic/472064-wifi-dropping-out/#findComment-6329182
