880m vs 970m .. help
Go to solution Solved by D2ultima,
Okay, Gotcha.
Now I know I'm going to get flamed a bit here, but. That Sager that you linked, how would it compare to this gigabyte one?
Gigabyte: http://www.newegg.com/Product/Product.aspx?Item=N82E16834233094&cm_re=970m-_-34-233-094-_-Product
I know the sager one has better cooling... But how does it pair up with eachother?
SINCE, Asus isn't a "reliable" Laptop company. And I'm really on a tight budget, really only have 1250ish at max.
The gigabyte isn't as good a machine, but it's not exactly "bad" either... except for its cooling issues and my general decision that any machine that can't handle the hardware you put in it is trash.
But the Sager model should be under $1250; you'd just need your own OS to install.
Hello all, I'm looking for a laptop in which I can do some gaming on, more on the MMO side. And also some school work etc. I'm really strict on my budget which is 1200. Give or take 50ish bucks.
I was looking around and found two Refurbished Laptops, Both are Asus ROG's.
I've looked at notebookcheck and it says roughly 15% difference in the 880m vs 970m. Now is that worth the 50 bucks? The 880m laptop has a insane amount of RAM, a SSD, and a blue ray drive/burner(Bonus!). While the 970m, has well the 970m and a IPS screen, does not have a ssd, but is 50 bucks more.
Also how are newegg refurbs generally?
The laptops:
880m: http://www.newegg.com/Product/Product.aspx?Item=N82E16834232162
970m: http://www.newegg.com/Product/Product.aspx?Item=N82E16834232464&cm_re=970m-_-34-232-464-_-Product
What do you guys think? Opinions?
https://linustechtips.com/topic/471309-880m-vs-970m-help/
The laptops:
Go with the SSD/RAM option, If its just MMO's which arent super graphics intensive it wont matter much.
That being said, you should look into Clevo/Metabox/Sager brands for laptops, which are usually cheaper but are very powerful still and highly customizable.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319572
The 970m is about 10-15% better performance, so if you need it, that's the way to go.  However, the SSD is a very nice thing to have so a better balance would be the 880m machine.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319585
DO NOT
EVER
UNDER ANY CIRCUMSTANCES
ON THIS PLANET
BUY A 880M
FOR ANY REASON WHATSOEVER
EVER
Also, don't buy an ASUS, especially refurbished. Consider this P670RE for about the same price as that 970M machine (you'll need your own OS though and no DVD drive, but it's brand new)
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319699
DO NOT
EVER
ON THIS PLANET
BUY A 880M
EVER
Ahhh, I haven't really went through the forum much, But aren't the problems with 880 SLI? Not just with the single 880? Also, Why is Asus bad / refurbished?
Didn't think about sager, thank you for that I'll consider that one for sure!
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319776
ASUS is known problematic and known for RMA hell. Refurbished ASUS machines are almost asking for trouble. And no, all 880Ms have issues; single ones are somewhat easier to tame, but they're not nearly fine. nVidrosoft claimed they'd fix them then stopped replying, released their 900M line and swept it under the rug.
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319836
Okay, Gotcha.
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6319858
Okay, Gotcha.
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6320029
Okay, Gotcha.
I would suggest the P670RE, which is the one that @D2ultima linked you, or get the 15.6" variant, the P650RE. The Gigabyte has looks kinda good but it is thicker whereas the P650RE is as thin as 25mm.
http://www.xoticpc.com/sager-np8657-clevo-p650re3-p-8677.html
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/471309-880m-vs-970m-help/#findComment-6320032
