MSI x79a-gd65 Help
Okay finally got my system to be fully functional again.
To any one who has this problem or is trying to "flash" a BIOS that isn't working here are my few cents on how to fix your problems.
First of all, all this information I am going to provide is from what I have read online.
- This M-Flash feature on MSI boards is supposedly very dodgy and many people have said that they have had problems with M-Flashing their board.
- Go to this link (https://forum-en.msi.com/index.php?topic=160450.0) and download the program there and follow the steps.
- I advice that you run the memtest86 program, it comes with the download and you can prompt to run the software off a bootable USB. It takes roughly an hour and a bit but if you have no error's then you should stand a good chance of flashing your BIOS with success.
- From there on-wards just read everything and all the steps and hopefully you get your mobo to a working order.
Please let me know if you need any help!
BTW Thanks mgsstar for taking the time to help me! Much Appreciated!
Thanks EDDYYZ
