Hey Guys
Im building my first pc and have apparently selected a pc case with slot for an optical drive, gg  -.- Because I bought my windows 10 as a cd, and also ofcourse have the software for the pc components.
I do have an old optical drive, from my old pc I could take out. Can I then just plug that into the MOBO, and have it laying on the ground next to the computer whilest I install what I need to install? And then afterwards remove it again? Thanks alot :) Sorry for noobness :D
Thanks :b
https://linustechtips.com/topic/469773-no-optical-drive/
Yes you can. I do the same.  :)
https://linustechtips.com/topic/469773-no-optical-drive/#findComment-6299645
Yes you can do that, alternatively you can do what i do as my pc nor my laptop have a optical drive cause personally i find them obsolete but necessary sometimes. Go buy a usb 3.0 external dvd drive. I use mine for burning copied movies to give to friends.
https://linustechtips.com/topic/469773-no-optical-drive/#findComment-6299662
You could just download the iso onto a usb and install from that, then enter the product key that came with the cd?
Main PC : CPU: I7 6700k @ 4.7GHz MOBO: Asus Maximus Hero VII RAM: 32GB Crucial 2133MHz GPU: GTX 980ti 2-Way SLI Drives: 2 850 Evo 250GB, 1 TB WD Blue CASE: 750D PSU: RM1000W
https://linustechtips.com/topic/469773-no-optical-drive/#findComment-6299665
good idea thanks :D
https://linustechtips.com/topic/469773-no-optical-drive/#findComment-6299667
