Which AIO and fans?
Go to solution Solved by JORDANonPC,
come on...at least read the op. Black with red or all black. My OCD won't allow mixed colours but thanks for the input though :D
you should just be using them in pull anyway so you wont even see them :)
Once again, going though post after post, I realised my upcoming build is still far from complete. This time around, I have noticed  the top of the 350D can house a 280mm rad and judging the pros and cons, I decided to go with it. The two most popular 280mm AIO seem to be the Corsair H110 and the NZXT Kraken x60 and to me they seem pretty much the same. However it is the fans which worry me the most as both stock fans are far from perfect.
The colour scheme for my build will be primarily black and red. What I require from my fans is that it has to be fairly quiet but strong performers. Black with some red or all black. PWM is not necessary however it will be nice to have it. Price is not an issue to me so I hope you can recommend me what you think will be the best that will suit my needs.
Also, excluding the fans, which AIO might perform better: the Corsair or NZXT?
Edit: Links will be usefull :D
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/46968-which-aio-and-fans/
there's also the Swiftec H220.
Getting ready for SAO? haha jk
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621559
They are the same re-badge.
I recommend going with the H220. It will perform better than the 280 radiator AIO units out there.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621562
Trust me, in the UK, you will not be able to find a single one.
Edit: Also, the price on the H220 is quite high as compared to a 280mm AIO. The AIO is basically a temporary fix for the first few years before I start a custom loop for my CPU and GPUs.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621567
Get Swiftech Helix 140mm fans They're black and white and great for rads.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621582
get h220 now and now you have a rad and pump for custom loop0
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621586
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621595
I'm actually going to be building a full custom loop with BitsPower crystal link as well as the d5 and upgrade kit (something similar to Singularity Computers). So the only thing salvageable from the h220 with be the rad which I will be swapping it out for a Blackice Stealth GT 280.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621603
hmm...thats actually quite a good idea. But will does the placement of the fans affect performance in any means? I'm going to be drawing air in and exhausting it out through the back so I was planning to put it below the rad but if it gives the same performance when put at the top, then I'll go for it.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621610
yeah having the fans in push or pull gives the same performance but pull is better because it makes dust easy to clean off your rad, so it will be best to have your rad exhausting like your back fan with the fans above the radiator  :)
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621619
Get a NH-D14 if this is temporary. Don't bother with a custom loop.
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621643
I did read it, I suggested what I though would be best there is very few red and black radiator fans. Go with what was suggested and pull the air through so you don't see the fans
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621677
Not a real fan of air coolers and since I am planning to push the clock speeds quite high, I'd doubt an air cooler will be sufficient for a 4770k.
Yup. That seems like the best option for the predicament I am in. Thanks everyone for your help!
https://linustechtips.com/topic/46968-which-aio-and-fans/#findComment-621682
