You can try setting the affinity to make it only use two cores.
https://linustechtips.com/topic/469452-help-disable-cores/#findComment-6295642
im running windows 10 and cant get fallout 3 to run i have a quad core and i think itll only use two cores how do i get game to work
It should be in the BIOS
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/469452-help-disable-cores/#findComment-6295650
? What do you mean ? Have you tried running compatibility mode?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/469452-help-disable-cores/#findComment-6295661
so what do i do
What happens when you launch Fallout 3? I've never played it so I don't know if you get a menu before entering the actual game(something like Skyrim).
https://linustechtips.com/topic/469452-help-disable-cores/#findComment-6295663
You shouldn't need to disable cores .
But anyway you can do that in the bios.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/469452-help-disable-cores/#findComment-6295778
