is this gonna be a gaming rig?
if so you dont need a i7... drop the i7 for like a 4460 or 4590 and get yourself a better gpu, the 750ti isnt that great a gpu at that budget
give me a few ill make some modifications to the build for ya
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295365
Well, I dont game much. But I would like something with a little umph when I want to. So yes.
what exactly will the pc be PRIMARILY used for
what your use case is will determine what will be the best build for you
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295391
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ NCIX US)
CPU Cooler: Noctua NH-L9i 57.5 CFM CPU Cooler ($42.49 @ OutletPC)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard ($120.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($51.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.33 @ OutletPC)
Video Card: Zotac GeForce GTX 970 4GB Video Card ($314.99 @ B&H)
Case: Cooler Master Elite 110 Mini ITX Tower Case ($38.99 @ SuperBiiz)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($85.68 @ SuperBiiz)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit) ($99.89 @ OutletPC)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($249.99 @ Adorama)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($115.12 @ Amazon)
Total: $1487.34
Generated by PCPartPicker 2015-10-18 15:07 EDT-0400
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295401
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($100.99 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($113.25 @ B&H)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($37.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($20.00)
Total: $1466.32
Generated by PCPartPicker 2015-10-18 15:04 EDT-0400
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295450
Total: $1487.34
Thank you good (sir? maam? whatever)
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295452
I found this build and I was wondering if it would work at all. Is it any good either? Thanks for anyone who helps.
http://pcpartpicker.com/user/HibbyHubby/saved/JTB6Mp
I was looking for something compact.
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($313.98 @ Newegg)
Total: $1546.89
Generated by PCPartPicker 2015-10-18 15:18 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295507
Thank you good people of the interwebs. Why do I even try to be formal? Anyway, If I get a build like this, it wont just explode in my face leaving a sour taste of regret and metal right?
not if you take your time, read the instructions and dont be afraid to ask questions on here if youre not sure what to do
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295511
Why's everyone going for an L9i? That thing's tiny :P
CPU Cooler: Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler  ($39.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($79.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 2GB ITX Compact Video Card  ($183.98 @ Newegg)
Total: $1382.47
Generated by PCPartPicker 2015-10-18 15:27 EDT-0400
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295522
I checked everything but just wanted to be sure. So I am ok having 2 hard drives and an ssd in this? Everything checked out but it doesnt feel like that would fit.
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295537
yep it will fit them
its the case he had picked so i stuck with it
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295545
Why have 2 separate 1TB drives when you can have 1 2TB drive for cheaper?
USEFUL LINKS:
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295555
SSDs can be stuck just about anywhere, as they have no spinning platters to worry about. If you have room for the hard drives, you can stick the SSD wherever the SATA cable will reach.
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295567
You'll need to check through a few reviews for the finer details of the case itself. This one suggest that mounting two 3.5 HDDs in the top bays would almost block the PSU intake (1cm to spare), and prove incompatible with bigger GPUs (750 may be fine tho). The likes of the 970 probably won't fit with an HDD mounted above it, and using the bay on the other side would block the main source of cool air to the PSU.
While many ITX boxes are 'compatible' with 3.5 inch drives, this is just a nice way of saying that the case has mounting points and/or drive bays. That doesn't unfortunately make them easy/convenient to fit, or fully compatible with gaming systems etc. Both 5.25 and 3.5 inch bays will often sacrifice airflow to other components and could increase temps quite a bit in a fully kitted out system.
https://linustechtips.com/topic/469430-will-this-build-work/#findComment-6295741
