 I was wondering, how does a desktop 6850 compare to a laptop 850M? Just curious. IIRC the 6850 is about the same as a 7770 in terms of performance.
https://linustechtips.com/topic/468776-need-input-on-2-totally-differnet-cards/
From what I can find, the 850m is slightly better.  The 6850 is about the same performance as a GTX 560, and that is the same performance as a Iris Pro 6200.  Did a search and 850m was slightly better than Iris Pro 6200, so by comparison should be better than the 6850 as well.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
I see. Thanks ^_^
Yep - between the 6850 and 6870 - a mild OC on a 6850 should reach it I believe.
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-850M-vs-AMD-HD-6850/m9138vsm7743
