Main Specs
i7 6700K
NZXT Kraken X61
MSI Z170 Krait Gaming Motherboard
Kingston HyperX DDR4 2133 2x8
1TB WD Blue
250GB Crucial BX100
Sapphire R9 390 Nitro
EVGA SuperNova 750W G2
NZXT H440
A few days ago I finished assembling my first PC and at first it worked fine and booted into the BIOS but now it doesn't turn on. I tested the power supply with the power supply tester EVGA provided in the box and the PSU ran fine (So did the fans on the Kraken X61 radiator) however when I plugged the 24 pin ATX onto the motherboard there's no indication of life and the entire PC doesn't power up. I also made sure all of the power connectors were in properly and it still won't power up. Did my motherboard get fried or is something else causing it?
Main Machine
6700K, Kraken X61, Z170 Krait Gaming, 16GB RAM, 250GB 850 EVO/ 1TB WD Blue, Sapphire R9 390, NZXT H440
Secondary Machine
Early 2011 17 inch Macbook Pro
https://linustechtips.com/topic/468545-possible-dead-motherboard/
Main Specs
i7 6700K
NZXT Kraken X61
1TB WD Blue
250GB Crucial BX100
NZXT H440
Are any led's on the mobo on?
Maybe fan's are spinning, when u switch it on?
From your words, it looks like a dead mobo for now.
You could accidently bend it, when put the cpu cooler on. But I don't think it's your fault.
No LEDS on the mobo (EZ Bug LED doesn't light up)
Main Machine
Secondary Machine
Test the motherboard outside the case.
Already tested outside of the case and it still doesn't turn on
Main Machine
Secondary Machine
