Thermal Throttleing CPU
Go to solution Solved by AresKrieger,
CPU temps IDLE 70°c
CPU temps load 99°c THERMAL THROTTLE 40-50% 2GHZ - 3GHZ
Cooler: H100I GTX
SPECS on my profile tell's 'Workstation' pc
3930K
Ok with this info, i'd say your paste isn't doing anything, or your contact to the cpu has a lot of air bubbles between it and the cooler. Either way you need reinstall the cooler and probably get new better paste
CPU temps IDLE 70°c
Cooler: H100I GTX
3930K
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/468244-thermal-throttleing-cpu/#findComment-6281530
Temps are back to normall 70°c! loud
Probably poor thermal paste or anything...
Now i used my new MX-2 8grams
https://linustechtips.com/topic/468244-thermal-throttleing-cpu/#findComment-6281652
