Thermal Compound ?
Go to solution Solved by Oshino Shinobu,
Just use the stock stuff. The difference between different TIM is only a few degrees at best, and the stuff EK includes is actually pretty good.
The standard ones what come with EK will be better anyway but it's down to personal preference and opinion of what you've found to work best.
EDIT:- IC Diamond is perfectly fine to use, there was a bad batch previously before but I've had a few tubes and used them on different CPU/CPU Coolers and never had any issues with scratching.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
https://linustechtips.com/topic/468190-thermal-compound/#findComment-6280845
Should I get extra thermal compound like the IC Diamond or use the stock ones that comes with EK waterblocks ?
The stock one that comes with the EK waterblocks is good enough.
At best you would see a difference of 1-2 °C. That's really not worth the money.
https://linustechtips.com/topic/468190-thermal-compound/#findComment-6280850
That save me $15 CAD(I am buying stuff from NCIX Canada)
MacBook Pro 13" Mid 2012 w/Core i5 3210M and glorious HD 4000 Graphics
https://linustechtips.com/topic/468190-thermal-compound/#findComment-6280854
