I mean the rest of the computer is fine but they tested it Before I received it so is it just possible that the fans dead?
First plug the fan into the motherboard headers, no one can say the fan is dead without ruling out the fan controller. If it is already plugged directly into the motherboard, try a different fan header.
Finding the cause requires you to rule out all the possible points of failure.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/467748-bios-help/#findComment-6275581
