In my first part list I set myself a $700 budget, that later rose to a big $1200. Since both of those are pretty high numbers to me I finally decided $500 Total max, lower is better. So this list is what happened, http://pcpartpicker.com/p/4sWsGX , some of the other people on PCPP said that It will run Minecraft at 60+fps While screen recording, then editing that video in say Sony Vegas or Adobe Premiere, one or the other haven't decided yet. But give me your feedback.
[CPU] - Intel Core i5-4590
[Motherboard] - MSI B85-G43 GAMING
[RAM] - Kingston HyperX Beast (2x4GB) 1866Mhz... CPU only supports 1600Mhz
[SSD] - A-Data SP600 128GB SSD
[HDD]- 1Tb Seagate Barracuda
[GPU] - EVGA GTX 1060 6GB SSC
[Case] - Corsair SPEC-03 White
[PSU] - Rosewill 450W 80+Bronze
https://linustechtips.com/topic/467655-mainly-minecraft-with-recording-and-editing/
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
Seriously though. your gonna regret that.
you have an extra 100$ in that list just upgrade the processor a little. an i3 with hyper threading would speed things up slightly
dear god man a Pentium? for rendering video?
 Budget man Budget
Get an i5/geforce 960
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Which i3?
Which i3?
i3-4170 its little more expensive than your original processor but its wont break the bank either
you better get a hard drive, recording will fill that ssd up WAY too faster
Indeed I have a 1tb HDD in my good ol' 2007 "semi-gaming" rig that will be adopted into it
http://pcpartpicker.com/p/WCjMkL   OK so here it is Better psu (for upgrades down the road) and Nicer case (only $1 more), an i3-4130, higher end RAM, and better Graphics card, Look Good?
you had your own pc when you were 6? man times have changed
No No no, it was handed down to me from a friend... GeForce 8800 GTX and amd Athlon x2 64 4850e, can not do what I need
