Urgent help with installation please
Go to solution Solved by Akadis,
Try opening the BIOS by pressing any of the following: F2, F12 or delete (not backspace)
If that doesn't work then go and unscrew your whole build. take out the COin cell battery on your motherboard while your whole build has no power  for at least 30 seconds then wait 10 seconds and then put it back in and retry it.
Otherwise you might have a problem or two:
1. Your CPU might be DOA or just dead (idk if you stepped on it xD or threw it across the room).
2. Your motherboard might be DOA (i'll stop with the joking here).
Go to the place you got your Mobo and the place you got your CPU and tell them it won't boot, they'll probably test it then ask you to either replace it or tell you what is broken and expect you to replace it or not tell you.
Good Luck. I had a similar problem to you when i built mine (except using haswell not skylake) and it turned out something happened to the mobo (idk if me or my friends stepped on it but we knew that a pin was bent).
All it takes is a single bent pin to cause it. Which is why you put pins on CPUs instead of mobos (like AMD!) and not intel.
I am so god damn stupid -.-
*Ultra Mega High End Face Palm Incoming*
I forgot the CPU Connector to the PSU
Hello
I am just bulding my pc and i ran into a problem
My Status:
  • MoBo (VIII HERO) is outside of the case (kind of testbench)
  • Ram installed (8GB dual channel)
  • CPU installed (i7 6700K)
  • H100i GTX is installed
  • and my PSU (HX850i) is installed
  • M2 SSD with 250 Gb is also installed
now I want to enter the Bios menu
Problem:
All Fans turn properly i can hear the pump working lights on tho mobo work and i have pluged in my keyboard and monitor (hdmi) but somehow nothing happens??
What can I do?
Thanks
Akadis
https://linustechtips.com/topic/467512-urgent-help-with-installation-please/
Hello
My Status:
Problem:
What can I do?
Thanks
Akadis
have you installed windows? also No GPU?
Hello
My Status:
Problem:
What can I do?
Thanks
Akadis
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
Nope doesn't work I don't even get a video signal onto my monitor it turns of because no video signal
also on the motherboard the 2 hex numbers stay at 00
the 6700K has an IGPU so something is werid.
Psss let me tell you something ................. ALL INTEL CPUs have a GPU die! Windows requires a GPU to run, either dedicated or integrated!
Look at my post again! I updated it.
This is what a coin cell battery looks like for reference. All motherboards have it.
Lithium-Button-Cell-Battery-CR2032-3V-21
Forget Windows, he can't get into the bios.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
Pins look fine
i unscrewed everything
taken out the  battery
still no change
Ignore this, didn't see the above. This was edited just after i saw the above.
LOL, that figures. It's ok to make noobish mistakes. HEY! At least it's not as bad as bending a pin on a mobo!
