Custom subnetting help?
Go to solution Solved by gazabi,
Alright so im taking a networking course in college and right now we are working on subnetting. the problem is no matter who explains it i just cant grasp custom subnet masks. Maybe some of you can help?
example:
# of needed subnets: 2000
# needed useable hosts: 15
Network Address 178.100.0.0
Address Class: B
Default Subnet Mask: 255.255.0.0
Custom Subnet Mask: 255.255.?.?
Total number of subnets: ____________
Total Number of hosts borrowed: _______________
Number of useable Addresses: _______________
Number of bits borrowed: __________________
                                        178   .  100   . 00000000 . 00000000
                                       IIIIIIII  . IIIIIIII  . 00000000 . 00000000
So im not sure where i should go from here. I know that the equation ((2^X) -2)) somehow works its way in but not sure exactly how or when. None of my materials help and the profs explanations are jibberish to me because he doesnt offer any reasoning on why it works the way he shows it and how to figure out what to use when and what each step does and why it works that way.
Any help would be greatly appreciated!
Thanks
I'll try to help. The formula works for since ip addresses uses binary, this gives the 2 in the 2^x. The x is the number of bits in the binary number, in one octet there are 8 (the 8 zeros). So 2 to the power of any number gives the total amount of different combinations or different addresses/networks. If you have 3 zeros or bits then it is 2^3 which comes out to 8, so 8 different possibilities. Now for the minus 2(used for calculating hosts not networks). The minus 2 is put there because in a range of addresses, the first is the network address and last is a broadcast address and  these cannot be used for the hosts.
Now for your problem. First I would get the total number of bits or x needed to get at least 15. Through using the formula given I would need 5, 4 is too small since it gives me only 4 usable addresses (remember the minus 2: 16-2=14). The 5 gives me 32 host addresses. The host bits are the last bits so it will be the last 5 zeros:
                                  IIIIIIII  . IIIIIIII  . 00000000 . 000|00000|
        |Host Bits|
Next is the network bits. We can use the same formula but without the minus 2. Since we have 16 zeros or bits and 5 of them were used in the host addresses this leaves 11 for the network bits. We need to get an x amount of bits which would give  us at least 2000 network possibilities. Using the equation 2^x I figured that the remaining 11 bits is just enough, giving us 2048 possible network addresses so we know that the 5 bits we borrowed for the users is just enough.
 IIIIIIII  . IIIIIIII  . 11111111 . 111|00000|
                         |     Network Bits      |Host Bits|
Since the default subnet mask was 255.255.0.0 and we borrowed 11 bits from the host portion(all that was zero was host) we know that 8 bits is 255 for the third octet (255.255.255.x) now for the remaining 3 we know it is 224 since the bits have a value from(left to right) 128,62,32,16,8,4,2 and 1, the leftmost 3 bits add up to 224. So the new subnet mask is 255.255.255.224. The usable hosts were calculated to be 30, the subnets/ networks were calculated to be 2048, and we borrowed 11 of the 16 zeros or bits for the network. The only thing I am not sure about is the hosts borrowed since I have never encountered that before.
example:
Address Class: B
Thanks
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/467420-custom-subnetting-help/
Quick addon:
I know that the subnet mask and the addresses that are filled in are represented by 8 1s. As well as that in order to get the rest of the mask you need to use the concept of borrowing the bits (0s) and however many of those bits you borrow correspond to the binary values that you add? together to make up the total number of hosts?
RAINBOWS!!!
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271220
Quick addon:
http://www.subnet-calculator.com/ during my CCNA class we used this tool to figure out what subnet to use based on how many users we had.
Pls Follow your own posts!      Chief Engineer for my School Studio, Own my own Home Studio also. I also do requests for Remixing songs too :D Storage Server: Mobo: Supermicro X8SIA-F Case: Some Supermicro 1U case Drives: 3x 2TB Seagate Barracuda 7200 RPM drives, 1x 3TB Seagate Barracuda 7200 RPM CPU: Intel Xeon X3430 2.4GHz Ram: 2x Kingston ECC 2GB sticks
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271237
The calculator would help with my worksheets but unfortunately we are required to show work and not allowed to use any tools during tests. thats why im asking the question.
RAINBOWS!!!
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271247
Ahh, I see :P If I knew how to actually do the work I would help but i don't :/
This might help break it down more.. http://www.tcpipguide.com/free/t_IPSubnettingStep3DeterminingTheCustomSubnetMask.htm
You can use this to find the 1st 2nd 3rd and 4th octet to go along with that table.. http://www.tcpipguide.com/free/t_IPDefaultSubnetMasksForAddressClassesABandC.htm
Edited by dark_xzyph3r
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271269
example:
Address Class: B
Thanks
        |Host Bits|
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271278
I really need to go for my CCNP cert lol
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271280
I had the opportunity to take it but didn't bother since I didn't plan on going into networking.
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271285
Yeah I want to go into networking lol, I did the CCNA cert and got it but really need to do the CCNP so I can actually get a job with it :P
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271291
Thanks for the answer. I think ive got it now. Your explanation was he first ive seen that makes sense to me.
Ill be posting what i have for steps on here later to flesh it out and maybe help others as well in the future :)
Thanks for those that responded and helped me.
RAINBOWS!!!
https://linustechtips.com/topic/467420-custom-subnetting-help/#findComment-6271489
