First of all i have no idea if i can even post this here but ill give it a go.
Friends computer has windows 10 now, and after a week or so she couldnt trun it on
It booted into brand logo and gave to F keys to click and shuts down.Either key you click on will make the computer makke a peeeeeeep sound and shutdown.
I would love help as im unware of what to do.
https://linustechtips.com/topic/467241-laptop-repair-help/
There are potentially several things that could be wrong with the laptop, and without being able to look at it in person it will be hard to diagnose, so I recommend you take it to someone who can take a look at it.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269002
Thanks for the sugestion but ive been told to replace disk or take ram out and put back in, would it even matter??
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269015
I don't know, perhaps and perhaps not.  Your question is like asking on Google "A friend I know has a fever, can anyone tell me what kind of sickness she has?"
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269021
There's really nothing you can do without looking at it. I would recommend if possible taking the battery out and then opening up and taking the hard drive out. Boot it up to see if it will boot without the hard drive. If it doesn't it most likely is the motherboard, ram or something. If it boots and you can get in the BIOS then it is most likely a bad hard drive or a bad OS install.
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269030
Has someone from a shop told you this? If so, have HIM do it - hire him to repair the laptop. That way any problem that messing around it may cause will be his fault and he has an obligation to fix it or give you your money back.
sudo chmod -R 000 /*
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269039
Ill try
That might be the best solution
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269052
If it's still under warranty, you should be able to get free servicing and repair, take it back to the store where it was bought.
https://linustechtips.com/topic/467241-laptop-repair-help/#findComment-6269085
