What transcoding preset Linus is using?
Go to solution Solved by Tedster,
Here's a video that may contain answers to your question, but your question may have also stemmed from watching that video.
Are you talking about his video encoding? if so H.264, otherwise I have no idea
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
What transcoding preset Linus is using on his 72 Cores server?
Any idea? Thanks!
Also follow your topics and you'll see the replies  :P
I don't think they have said what settings they use. I don't recommend you copy their settings though. If you want to encode something to h.264 then set the RF as low your storage can handle (lower = bigger files but better quality) and set the preset to as slow as you can handle (slower preset = smaller file and/or higher quality, but takes longer to process).
