Just like the title says
Give me the pros and cons for each one please :)
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/466927-aio-custom-loop-or-air-cooling/
it depends
on budget and experience. AIO is easy great performance but standard and not unique. custom loop is the best but expensive and very unique. air cooling cheap and does the job but sometimes ugly af imo.
"God created war so that Americans would learn geography"
it depends
If I just want to cool the CPU alone? What will perform better a custom loop or an AIO?
custom depends on the budget. but for a decent overclock something like the kraken x61 or the ek predator 240 will be more than enough
Price to performance:
Air > AIO > Custom Loop
Reliability/Endurance:
Air > AIO >= Custom Loop (as reliable but higher maintenance)
Looks:
Custom Loop > AIO  (Air is all over the place and subject to opinion)
Raw Performance: (assuming top of the range, custom depends on number of rads)
Custom Loop >= AIO > Air
Feeling of satisfaction after installing:
Custom Loop >>> AIO = AIr
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Looks:
I'll be building in the corsair 380T I know I can fit a 240 rad in there but I'm limited when it comes to air coolers
im currently building in the same case xD i decided to go with the noctua u9s tho with dual fan
Does it fit?!
ah, A custom loop would be a bit pointless then (since one of the main reasons is to get more use out of the rad mounts on the case)
an AIO would give better raw performance, but there are some powerful air coolers in the height restricted market, especially from Cryorig.
the biggest cooler you can fit in there would be the Cryorig H7 (literally 5mm clearance)
These coolers are really hard to find where I live and I have to order them from outside to get them, how would the H100i GTX perform against that air cooler?
probably
probably
That doesn't answer my question :P
derp, the H100i GTX should be considerably better, just make sure the combined thickness of the radiator and fans (25mm) is less than 55mm, otherwise it interferes with the motherboard
Yeah, Dimitry was able to install it with one row of fans in pull
