RAM problem
Go to solution Solved by failblox,
What application is telling you that your RAM is being closed to maxed out? I suspect the program is just acting up.
So I am getting a message when i play games saying my ram is close to being maxed out, however i look in task manager and it says only half of the ram is being used (i have 8gb btw). So my question is why is it telling me my ram is close to maxing out,i run on windows 10 if that helps.
CPU Ryzen 5 3600 | Motherboard MSI B550 | RAM 32 GB Corsair Vengance Pro | GPU EVGA GTX 980ti | Case Corsair 4000X | Storage Seagate Barracuda 2TB HDD,  Team GX2 1TB SSD | PSU Sentey 850w 80+ Bronze | Cooling AMD Wraith RGB | PCPartPicker URL https://pcpartpicker.com/list/RN7kGc |
https://linustechtips.com/topic/466906-ram-problem/
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/466906-ram-problem/#findComment-6264591
Lel what program is it it might even be a virus xD
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/466906-ram-problem/#findComment-6264667
GTA V and Star wars battle front beta, sorry i didnt respond immidiatly.
https://linustechtips.com/topic/466906-ram-problem/#findComment-6270020
are there any other like big programs ? that work on the background also do you use a program from a company that you might not trust/not populair ?
https://linustechtips.com/topic/466906-ram-problem/#findComment-6280251
no
https://linustechtips.com/topic/466906-ram-problem/#findComment-6289060
