looking for some help
I have a Dell monitor connected to my evga gtx 970 via display port
its full size display port on the card and the mini display port on the monitor but whenever i turn it on its not detecting the display sometimes
its done this twice now and i havent a clue how to make it work this time
if i use HDMI its fine, it works no problem but i dont want to run it on hdmi because i use it for my TV
when i turn the display on it just says entering power save mode and says that its not receiving a signal from  the computer
i have tried using windows display detect button but it just comes up saying another display not connected?
i have looked in the nvidia control panel as well and its not showing anything?
does anyone know how to fix this??
https://linustechtips.com/topic/466793-no-display-help/
Try another DP cable.  If that doesn't work, try another monitor via DP.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/466793-no-display-help/#findComment-6263141
i only have one display cable and one monitor that has display port.
the problem only comes up sometimes whenever i have my tv connect via hdmi and monitor via display port
id put a movie onto the tv and turn off my monitor thats when i would usually get this problem
https://linustechtips.com/topic/466793-no-display-help/#findComment-6263169
Try other connections like DVI or VGA.  Check your GPU drivers also.
https://linustechtips.com/topic/466793-no-display-help/#findComment-6263195
it works fine with HDMI but i wanna use HDMI for my TV and my GPU Drivers where just updated not long ago :/
really dont have any clue anymore what else to try
there's no bends or breaks or anything in the display cable so im really not sure
https://linustechtips.com/topic/466793-no-display-help/#findComment-6267843
