How many threads are you going to make about this mate? Just make one thread with everything you wanna ask including all criteria that you want to meet.
If you're that worried about aesthetics, you can get a Be Quiet Shadow Rock. If not, you can get a better cooler from Noctua like the NH-U14s.
https://linustechtips.com/topic/466515-build-color-scheme/#findComment-6259701
this ones about 73 euros it looks good and matches the color scheme http://www.newegg.com/Product/Product.aspx?Item=N82E16835103189
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/466515-build-color-scheme/#findComment-6259702
The performance on that thing is garbage compared to what you can get by just replacing the fans on a better cooler from Noctua or whomever else have good heatsinks.
https://linustechtips.com/topic/466515-build-color-scheme/#findComment-6259716
true but i am into aesthetics more than performance just giving him that option
https://linustechtips.com/topic/466515-build-color-scheme/#findComment-6259869
